Hello all!
This is my first post on this forum. I've been planning out a build for a little while now and I'm not sure which mATX case to use in my build. Here is one of my planned builds:
Intel Core i5 4440
CM Hyper 212 Evo
AsRock Z87M Extreme 4
Gigabyte GTX 780 OC
Intel 330 120GB SSD (Salvaged From Laptop)
Seagate Barracuda 1TB
Patriot Signature 8GB 1600 MHz
Corsair GS600-V2
Samsung SATA DVD RW
These parts all up will cost me about $1251 (I live in Aus and my budget is $1400). The cases I've shortlisted are:
Areocool Dead Silence Cube - $125
Corsair Obsidian 350D - $149
Bitfenix Colossus M - $119
Fractal Design ARC Mini R2 - $125
Which case would be the best for my build? Also, is the 600W power supply enough for the system? I plan to overclock my GPU.
Thanks!
Asus MAXIMUS VII Gene 2 x 8GB G.Skill 16GB 1600 Mhz Intel 4670k @ 4.3 Ghz Corsair H100i w/ stock fans EVGA GTX 770 SC Intel 750 Series SSD 240GB, Samsung 840 SSD 240GB WD Caviar Green 2TB Seasonic X-650 V3 2 x 140 mm Noctua A14 PPC, 120mm LED Corsair AF120
https://linustechtips.com/topic/104537-matx-cases-help/
The Fractal and the Corsair have the best cooling and cable management.
CPU: i7-3930K @ 4.8GHz MOBO: IV Gene RAM: 16GB Crucial Ballistix Tactical Tracer 1866MHz GPU: GTX 780 Ti CASE: Corsair 350D STORAGE: 2 x Samsung 840 Pro 256 GB, 2x WD Red 4TB
PSU
: EVGA SuperNova 650W DISPLAY: 1 x ASUS VG248QE, 3 x Dell U2414H COOLING: Corsair H100i INPUT: Corsair Vengeance K70, SteelSeries Sensei AUDIO: Sennheiser HD 280 Pro, ATH-M50s, Beredynamic DT770 Pro, Steelseries H Wireless
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398041
Is there any advantage in spending $25 more on the 350D besides just spending more?
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398092
Larger side window for one.
PSU
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398112
Hmm ok.. Are there any other cases I should be looking at besides? I'd kinda like to make this build as small as possible. Also, I'd quite like to have the CD/DVD drive still.
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398127
Did you consider the Cooler Master N200 (AU$64) or the Fractal Design Core 1000 USB 3.0 Black mATX Tower (FD-CA-CORE-1000-USB3-BL) (AU$69)  - not sure on availability of the later.
600W should be sufficient for the system outlined.
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398138
You should also consider the Silverstone Sugo SG10  : http://www.newegg.com/Product/Product.aspx?Item=N82E16811163237
Not the prettiest (although I like it's sleek front and simplistic exterior), it has really great airflow, fits large coolers and large graphics cards.
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398156
What will you be using it for? LAN parties, small living area or are you frequently moving? If it's LANs than you can just get something with a handle.
Best mATX evah!?
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398199
My suggestion: Silverstone TJ08. I own it, and can vouch for it. It is an excellent case, but cramped if you use the hard drive cage. Keep in mind the Hyper 212's fan must be mounted behind the heatsink in a pull, due to clearance issues with the hard drive cage. Here's a view of mine without a video card. One native SSD slot, which is under the external 3.5" bay.
266914_10151304179215944_1539510405_o.jp
EDIT: Must be dyslexic today, got the model wrong like 4 times :(
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398200
I would recommend the Bitfenix Phenom. It is a small, modern looking case and I LOVE it. It will fit your hyper 212 evo and looks good :)
RIG: Processor: Intel Core i3 4130 MoBo: ASUS H81M-PLUS RAM: 4GB Corsair Vengeance DDR3 1600MHz Storage: 1TB WD Blue PSU: 450W Cooler Master OEM CASE: Corsair 350D
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398242
The Core 1000 doesn't have enough clearance for the 212 Evo.
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1398356
The mATX Bitfenix Colossus ...Donno why but that little thing looks neat to me.. and I hate case LEDS
Ugh, I can't stand doors on the front of the case!
Gaming PC
  • Storage:
  • W11Pro
Media Server
  • Unraid 6.9.2
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1403697
  • 4 weeks later...
Whoa. Uhh... first things, first, sorry for not replying to the thread I didn't get ANY notifications at all about new posts. Also sorry if reviving a thread like this isn't allowed.
I had a look at the Colossus. I'm just worried about the cooling performance and the cable management. I do like the look of the case but yeah, the door is kinda meh
I did consider that case! I would kinda like a CD/DVD drive though. Cooling is also a worry for me (It can reach 42 degrees here in Melb)
The Silverstone is one of the cases I've looked at recently (The TJ08-E and the PS07 w/ window). How is the cooling performance of that front fan?
Best mATX evah!?
I would be using it for gaming? I would take it to the occasional LAN party but those are pretty rare these days (I'm studying engineering. Not the most amount of time) I don't really want to mod cases btw.
The Aerocool also has very good cable management, same interior as the Xigmatech Aquila.
I can't get Xigmatech in Aus sadly. The Aerocool is lower down on the list now as it's not that much smaller than the Arc Mini R2 as I've been reading around and the extent of the cable management seems to be stuffing some of the cables behind the GPU.
The SG10 looks alright although the SG09 is $30 cheaper however.
I actually haven't looked at any Coolermaster cases. The N200 looks pretty good but I'm not quite sure where to pick one up locally. I'll have to do some more research on it. I looked at the Core 1000. I do like it, but it doesn't fit all that much in it.
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1550405
I haven't measured temps in quite awhile, nor have I tried overclocking since the first time it started crashing, but because the inside of the case is so small, the 180mm fan does a pretty darn good job. I've always wanted to swap it out for the white Air Penetrator fan, which is a ball-bearing fan and goes up to a higher RPM than the stock black one, but I never have this one running full speed anyways, so it's probably a waste of money.
The case is pretty small given the fact that it's a mATX tower case, but because I have three mechanical hard drives, it's pretty heavy.
I eventually want to swap the case to a Corsair 350D, it would be bigger, but much more room to work with, and support for a dual 120m all-in-one cooler.
Gaming PC
  • Storage:
  • W11Pro
Media Server
  • Unraid 6.9.2
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/104537-matx-cases-help/#findComment-1552704
