Best quiet RGB fan for water cooling
joselcl98
Right now I have 6 enermax rgb fans, in a p7 thermaltake, but I only have it in the middle of the fans because they make an unbearable noise, I think it's because of the piece of box, but I do not know.
I want to put in the future the 12 fans and I want them to be quiet and rgb. I've been watching the corsair LL140, they call me a lot but not if they make a lot of noise, I hope not for that price.
Would you recommend some of the Corsair's?
I have 3 LL120 Black RGB 1500rpm on my 360mm with a pretty high fin count and they do a good job at moving air though. I also have LL120 White RGB 2200rpm and they get to loud for me at 1800rpm. I use negative pressure in my 500d rgb with the Whites in the roof and rear and the 3 blacks in the front. At full loads on my build listed in signature CPU maxes out at 64c and the GPU about 68c. That is with a max fan curve of the 1800rpm whites and 1300rpm blacks.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
already, but mine is a thermaltake p7, there is no pressure
