Hello,
My cpu becomes too hot when i game. It causes fps drops. I used to play fortnite with 50+fps now , i cant go upto 30. I played league of legends with 100+fps but now I cant go up then 60.
Yes, I dont have fps capped at 60. Can someone tell me how to fix this. I have cleaned it, applied good thermal paste but still the issue isn't resolved. At iddle the temps are above 70 C and while gaming it goes upto 100C.
Need Help.
https://linustechtips.com/topic/1045141-cpu-is-too-hot/
get a better cooler
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12398699
Were you able to before? This is a low end Dual Core CPU, with a Low end 830m Graphics chip, i dont expect this to be able to do all that much
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12398767
Under "Clock Speeds" says your GPU should be 1Ghz. From your hardware monitor screenshot i see the max clock was 405Mhz. That should explain the FPS drop.
can you post GPU temp? it may be throttling. Your CPU is 90ºC but is not showing signs of throttling, it's not its fault.
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12398845
@Shimejii It may be low end but I used to play most multiplayer games at 35-50 fps. But now I cant.
@trevb0t Yes the cooler is working. I have confirmed that.
@faziten that happens when I dont play game. When I start a game it goes up. When I put load on the cpu, it starts thermal throttling.
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12399595
how old is your laptop?
It might be worth a shot to replace the thermal paste.
Also, how is the airflow for the bottom of the laptop.
If you have it flat on a table (or worse, on carpet or something) it will starve for fresh air, and can overheat.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12399823
What is the model of the laptop?
Its completely normal for laptops to get really hot during gaming sessions. I have a gaming laptop which has a pretty decent cooling solution and the cpu is around the 70's and 80's while gaming at low settings, I am utilizing Arctic Silver 5 thermal paste. Before applying the new paste I was close to the 90's and I never game on my laptop for more than an hour at a time. My laptop specs are i7 4710hq and GTX 860m.
If you haven't tried already, invest in a dual fan laptop cooling pad. It brings my temps down slightly.
Intel Core i7 9700F / Cooler Master 212 Evo / GeForce GTX 1660 SUPER / 16 GB G.SKILL RAM @ 2666MHz / GA-B365M-DS3H / EVGA 500w PSU
HP Pavilion Gaming 15 / Ryzen 5 4600H / GeForce GTX 1050 / 8 GB @ 3200MHz
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12403146
If you were once able to at much lower temps, I'd say something's wrong with the cooler.
Normally, I'd say clean out the internals of any dust and if needs be replace the cooler, but being a laptop I've no idea if you can do those things?
M/Board: Gigabyte AORUS X470 Ultra Gaming || CPU: AMD Ryzen 5 2600X || Cooler: Wraith MAX || RAM: 16GB Corsair Vengeance RGB || GPU: ASIS Strix Radeon Vega 56 || Storage: WD Black 500GB NVMe & 2TB Seagate BarraCuda HDD || Case: Sahara P35 RGB mid-tower || PSU: EVGA SuperNOVA G1 650W
Art Tablets: UGEE 15.6" Graphics Monitor & XP-Pen 15.6" Display Tablet
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12403245
is the fan woking and is the cooler tightend down?
(Take anything I say with a grain of salt)
[Main Pc] CPU, i5 9600k GPU, Asus Strix RTX 2060, RAM, 16b Team Group Delta RGB, PSU, Seasonic Px-750 plat , Cooler, Cooler Master MasterLiquid Lite ML120L RGB, Storage, 500gb Samsung 950 evo/1tb WD blue/2tb HDD,Case, Enermax ECA3520. + some cooler master RGB fans
[Laptop] Dell G3, i7-8750H (Turbo 4.2 Ghz), Gtx 1050 ti , 8gb 2669 mhz, 128gb nvme ssd, 1tb HDD
[Server]
[Consoles] Pretty much almost every popular one you can think of besides for like Xbox and some Sega Stuff( Playstation especially)
[Mobile Devices] iPhone XR 64gb (Red) gb, iPad Air 2 128gb, Space Grey,  Ipod Shuffle Space Grey
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12403496
@gucciguy cant undervolt it.
@Brent744 model is p206tx. i5 5200u and gt 830m.
@Gareque I have cleaned it many times, but it does not do anything.
@Lagercat1 yes the fan is working.
@Benjeh its not the gpu that is heating it is the cpu. Even without the games, the cpu sometimes start thermal throttling even when i am just watching a video on chrome.
@belfouf yes i have cleaned it thoroughly but it doesn't do shit. Nope i did not tempered with the voltage.
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12408905
Sounds like you need to check your TIM and Heatsink mounting unless your smothering the laptop in blankets or such instead of using it in the open with back raised for decent airflow.
Why cant you undervolt it?
It's a 15W CPU which usually idles with less than 1W if C-States are reported. Also check if it has any features such as "crap and quiet", or something named like that, enabled.
AWOL
https://linustechtips.com/topic/1045141-cpu-is-too-hot/#findComment-12409147
