[SOLVED]Need help with Memtest results
Go to solution Solved by 191x7,
If you enter something in the memory and reads it, it has to be the thing you entered and not something else. In your case what was entered into memory and what was read wasn't the same. Memory corrupt.
Hello everybody !
Since a few days I noticed some strange behaviours on my desktop (Mouse freez, FPS drops in game that I don't have normaly...). So I decided to check everything. I performed a MEMTEST86 to see if my ram was working properly, I run the test twice. After those tests, 3 errors came out (2 on the first run, and 1 on the second run). The issue is, I didn't found some really information about those results, so if someone could give me some little help, it would be awesome !
/ * / Config / * /
Proco: Intel Core i5-4460 3.4GHz
Ram: 2x4GB G.Skills Ripjaws X (ref: GSKILL-F3-12800CL9D-8GBXL)
Graphic Card: GTX 1060 OC KFA2
Motherboard: MSI H97M-E35
Thanks in advance lads
Edited by Xosten
SOLVED
https://linustechtips.com/topic/1044763-solvedneed-help-with-memtest-results/
Bad memory. Test one module at a time and replace the one that has the error.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Thanks for the quick reply. Do you have an idea more technicaly what the issue is or not ? Because the only thing I understand is that he red the wrong value that he should normaly ?
Allright, thanks man :)
Have you found which of your memory modules is broken and replaced it?
