I have the DEEPCOOL Matrexx 55 case, which comes with an rgb led bar installed on the front, I think the manual is telling me to plug the wire called MAIN into the 12vrgb header but it isnt long enough and it is the only wire that would even be able to fit in my motherboard. It comes with a connector which goes from MAIN to 4pin but i'm not sure where to plug the 4 pin into? Any HELP
http://www.deepcool.com/product/case/2018-07/9_8726.shtml
https://linustechtips.com/topic/1044749-rgb-not-working-deepcool-matrexx55/
