Just now, undrac86 said:
I would say even? The case is an h400 and the radiator exhausts out the back.
And tubes are under the rad? It might not make a difference but if there is some air in the loop you want it to settle to the radiator and not in the pump block or tubes.
https://linustechtips.com/topic/1043834-cpu-temps-too-high/#findComment-12387304
Okay so reapplied the paste... Aaaand it seems a little better but no. Pics of temps and mounting. I have no ideas.
Edit: Also, I didn't feel the radiator itself, but the airflow coming out of it was very cool. #stillNoIdeas
Edited by undrac86
Additional Information
https://linustechtips.com/topic/1043834-cpu-temps-too-high/#findComment-12387667
so the rad and pump etc aren't getting hot at all? To be honest with you, when ever I get an Intel CPU I just delid it and go from there. My 6700k had such bad temps out the box I quickly shut it down, took my loop apart and got ready for hard line tubing while delidding the 6700k. Temps shot down.
https://linustechtips.com/topic/1043834-cpu-temps-too-high/#findComment-12387965
I think its just the cooler in this case and making sure I wasn't missing something... I was testing this against an air cooled (old intel basic one) i7-6700K and it didn't get to 100°C. Thanks for the help guys... Do you have any recommendations for a 120mm rad AIO Water Cooler?
https://linustechtips.com/topic/1043834-cpu-temps-too-high/#findComment-12388159
Not really but I would suggest a bigger radiator 280-360mm.
https://linustechtips.com/topic/1043834-cpu-temps-too-high/#findComment-12389331
On 3/13/2019 at 6:16 AM, undrac86 said:
I have a i5-9600K Stock and Kraken M22 and the temps are:
idle 55°C+
prime95 100°C+
Now I’m sure thats not right... it does turbo to well over 4Ghz while running tho. Any thoughts?
If the rad isnt getting hot , its likely the pump is not running.
make sure you have it powered/wired in correctly, if its still not working at that point, its a dead unit.
Since ur runnign a 120mm Unit i would sugest a refund if u can get it, and find a good air cooler, it will perform better for the price and wont have the same poitns of failure AIO's have.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1043834-cpu-temps-too-high/#findComment-12391936
Update: I got this product a bit ago, so RMA'ing is way out of the question... I went ahead and got a new unit.
In the mean time, I installed CAM but only the lighting effects are avail. None of the pump settings or fan settings seem to be detectable. Thanks for everyone's help on this one :)
https://linustechtips.com/topic/1043834-cpu-temps-too-high/#findComment-12398112
