70-80 is fine
Though if you want to lower it, you can adjust your fan curve
https://linustechtips.com/topic/1043600-gpu-temps-help/#findComment-12385021
Just now, cyberphy said:
I tried to increase the fan curve but it sounds like an airplane is going to takeoff in my room
Well don't set it at 100%, just incremental based on  temperature
https://linustechtips.com/topic/1043600-gpu-temps-help/#findComment-12385028
59 minutes ago, cyberphy said:
When I get above 50% it just gets really noisy the higher I go
Well either way, your temperatures are fine
https://linustechtips.com/topic/1043600-gpu-temps-help/#findComment-12385230
