4 minutes ago, Petray671 said:
is 32gb of ddr4 2666 better than 16gb of ddr4 3000?
If amd, the use 16gb ddr4 3200, amd doesn't really support 3000, unless you manually want to tune to 2933 or 3200
If you're formally an engineer, avoid responsibility. That's what senior engineers get paid for.
https://linustechtips.com/topic/1042953-what-is-more-better/#findComment-12379478
4 minutes ago, AGames2911 said:
intel or amd build?
i would go for the higher capacity if its intel
Depending on the use case i would use 32gb its basically a waste, when gaming
https://linustechtips.com/topic/1042953-what-is-more-better/#findComment-12379484
depends on use case. If what you're doing uses more than 16GB memory, then 32GB is better because running out of memory slows things down considerably. If you don't, then 16GB is better because it is faster. Note that this is only true when they are both in dual channel mode, so you need 2 8GB sticks or 4 4GB sticks for the 16GB configuration.
Desktop benching:
https://linustechtips.com/topic/1042953-what-is-more-better/#findComment-12379497
This question doesn't make sense.  Do you really need more then 16GB of RAM ?  Do you do content creation or video editing and stuff like that ?  Also 2400Mhz or 3200Mhz you will NOT see a real world performance difference.  Maybe 2fps more in games.  I would get the 32GB kit, but that's just me.  If you feel your going to use more then 16GB then grab the 32GB kit and don't look back.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1042953-what-is-more-better/#findComment-12379516
22 minutes ago, Petray671 said:
sorry about the question, im going to use it for editing and gaming
Trying to help simplify this:
If you already have 16GB of RAM and need more for editing (and can tell you're maxing the 16GB) then go for more.
If you are more concerned about gaming as a 1st priority, get your ram speed above 2800 as your AMD CPU is memory hungry and will take what you can give it for memory frequency (like up to DDR4-3200 as stated above, AMD typically doesn't pull much higher even if the mem kit is rated for more).
https://linustechtips.com/topic/1042953-what-is-more-better/#findComment-12379616
Just get 16GB of the fastest speed you can afford... If you were doing work that required 32GB or RAM, you'd have your answer already.
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
https://linustechtips.com/topic/1042953-what-is-more-better/#findComment-12380007
32GB if you want more future proofing and you're actually doing work/editing that needs a lot of ram.
More is always more better ?? unless you need more faster. Lol
Primary Rig:
CPU: AMD 7800X3D @ Stock PBO - Mobo: Gigabyte X670E AORUS Master
2 x 48GB G.Skill Trident Z Royal 6400MHz CL32 1.35V @ 6200MHz CL28-37-32-30 1.5V (still tuning)
CPU Cooler: EK AIO that will be being replaced when I get the chance - PSU: eVGA P2 1200W
GPU: Gigabyte RTX 4090 Gaming OC @ either 2595MHz @ 900mV or 2970MHz @ 1070mV
Case: Thermaltake View 91 - SSDs/HDDs: 1 Samsung 980 Pro 2TB, 2 990 Pro 2TB M.2s, 1 990 Pro 4TB M.2, 1 TeamGroup Cardea Z440 2TB M.2, 1 Seagate EXO X10 10TB HDD
Monitor: Samsung Odyssey G9 49" Super-Ultrawide 240Hz Monitor
https://linustechtips.com/topic/1042953-what-is-more-better/#findComment-12380216
