I bought a cheap dell xps 8500 for $150 and bought a xfx rx 580 8gb for $140 but most my games are capped at 60fps
TV
Intel i7-3770@3.40ghz
12gb ram
Rx 580 8gb
Dell A14 bios
Is this what i should be getting or am i getting bottlenecked somewhere, my guess is prob the motherboard or the tv
https://linustechtips.com/topic/1042775-need-help-with-cheap-pc-build/
1 hour ago, NineEyeRon said:
What are the games?
Some games have an FPS cap.
What are your normal FPS? 30-50? 50-60 or always 60?
How are you measuring FPS?
I do the ingame benchmarks like gta v and the normal benchmarking programs,
Went from a gt 640(30fps on gta) to an rx 580
It is a constant 60 fps
Here's a user benchmark,  https://www.userbenchmark.com/UserRun/15356262
Ive been told it may be a motherboard and power bottleneck
TV
12gb ram
Rx 580 8gb
Dell A14 bios
check that vsync is not enabled on each game
my current home setup:cpu:amd ryzen 2700 // cpu cooler :aigo 120mm aio // mobo:gigabyte ab350-gaming 3 // ram:crosair vengance 8*4 // gpu:amd rx 5700 //
tower:antec p8 // psu:antec HCG 650w.
my current work setup: cpu:intel xeon x5675 // cpu cooler :generic 6 copper pipe // mobo: x58 lga 1366 chines motherboard // ram: 32GB ecc // gpu:amd r7 260x //
psu:antec 550w.
my current home server setup:cpu:intel xeon x5690 // cpu cooler :aigo 120mm aio // mobo: x58 lga 1366 chines motherboard // ram:crucial 8*2 // gpu:amd rx 580 //
tower:antec p110 silent // psu:antec HCG 850w.
