rgb fan kit hurdle HELP!!!!
Polktergeist
so i posted this in another thread butim pretty sure it was the wrong thread. but i have a rgb fan hub thaty requires a 4 pin molex connector my mother board or my power supply has one so can i use a sata to 4 pin molex to provide proper power to my rgb fan hub?
Yes, you can.
Your other thread was more appropriate.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
As Semper said, yes you can. You can also possibly (depending on your hub) do some basic modding, and connect to one of your motherboard headers.
