What cpu do you have? And can you see its usage during these scenes?
City scenes in GTA V seem really cpu intensive which might be causing a bottleneck.
You could (possibly) reduce this effect by turning down the render distance and density in the Advanced Graphics, and the Graphics settings.
https://linustechtips.com/topic/1042547-low-gpu-usage/#findComment-12376086
i have a Ryzen 5 2600, it says around 30-40% (less than GPU). sometimes when i launch the game the GPU usage is around 80-95 and the fps is around 80 but sometimes again its 50-60% at the same scene and the fps is at 60
https://linustechtips.com/topic/1042547-low-gpu-usage/#findComment-12376095
Turn off v sync
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1042547-low-gpu-usage/#findComment-12376181
its weird, sometimes when i open any game now, its fine but then next time i launch it, the gpu usage is around 30%
causing low fps. i reopen the game it runs fine but it feels laggy. i just played a game called Dirty bomb and the gpu usage was
stuck at 30% and caused low fps, reopened the game and usage was around 50-60% and gave me decent fps but still
felt laggy.
https://linustechtips.com/topic/1042547-low-gpu-usage/#findComment-12385040
