I'm planing to get a new gpu and there's two options in my mind , an msi rtx 2080 witch cost 700$ or a zotac 2070 amp extreme edition  witch cost 520$ for the 20700c option and 500$ for the 20700b option .
so what should I get and what is the difference between 20700c option and 20800b option . thanks :)
links :
zotac 2070 "this is the 20700b option": https://www.newegg.com/Product/Product.aspx?item=N82E16814500442
zotac 2070 "this is the 20700c option" https://www.newegg.com/Product/Product.aspx?item=N82E16814500443
msi 2080 : https://www.newegg.com/Product/Product.aspx?Item=N82E16814137375&Description=rtf%202080&cm_re=rtf_2080-_-14-137-375-_-Product
https://linustechtips.com/topic/1042455-help-needed/
30 minutes ago, MilkTeaAndTwix said:
Get a used 1080ti for like $500 off ebay
but what's your monitor resolution/refresh rate?
https://linustechtips.com/topic/1042455-help-needed/#findComment-12375524
36 minutes ago, MilkTeaAndTwix said:
full hd 144hz , I can't order from ebay because most of the sellers won't ship it to my country .
What country? Is there no local used options either for about the same price as the 2070?
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376156
links :
1080p 144hz is perfect for a 2070. If you need more power for later on then 2080 but the 2070 is a good card( I have one i know).
Mainboard:ROG-STRIX-B360-G-GAMING/Cpu:I5 8400 /Gpu: Galax RTX 2070 /Ram: Corsair Vengeance 16 GB DDR4/ Storage:1TB HDD 2 Corsair SSD PSU : Corsair 550W/Cooling: Silverstone Air Cooler/ / Case : Corsair/Keyboard:Razer Chroma TKL/Mouse:Mionix Castor+Steelseries Qck Mass/Headphone:V Moda M100
Quote me if you when me to reply to something.
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376578
5 minutes ago, MilkTeaAndTwix said:
the moment I tell you you will understand why , cause I live in Saudi Arabia . and the used options are overpriced :(
Then ya I have no idea.
But if you're only gaming at 1080p 144hz, an RX 580 8GB is good enough at medium settings. An RTX 2060 would be more for high/ultra gaming.
Anything past that is becoming a bit overkill for the resolution.
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376585
but my gpu is a bottleneck , and I want something for the future .
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376641
2070 is definitely not for the future, so u either save money with a 2060 or go with a 2080.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376659
The 2070 is better then the 1080 when oc. The 2070 is not a weak card and it won't bottleneck your cpu. even a 2060 like xg32 said a 2060 will be fine too. But since you want a card for the future to come then go for 2080 for sure.
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376664
The 2060 is only about 10-15% slower than the 2070 depending on the game
CPUs bottleneck max fps/refresh rate
GPUs bottleneck resolution/quality settings.
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376667
In some asian country including mine the price of 2060 and 2070 is really close. by paying $50 more i can get a 2070 instead of a 2060 in my country which is why i got my card.
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376670
True but it have more vram though. I know RE2 eat up a shit ton of vram and so does apex legend when you put it on full ultra
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376673
1080p 144hz doesn't need the extra vram, and no1 who plays apex seriously do ultra, the 2070 is just a horrible deal overall, which is why we are recommending a 2060 or a 2080, unless local prices differ. if it's 520 for a 2070 and 700 for a 2080, go with a 2080.
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376719
the diffrence between the 2060 and 2070 is 150$ , and the 2070 and 2080 is 230$ .
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376741
ya with a 150usd difference, the 2060 is a nice buy.
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376746
3 minutes ago, MilkTeaAndTwix said:
ok last question is the 2080 and i7 8700k good pair ?
yes, if you are not gonna upgrade your monitor or gpu for 3-5 years, the 2080 is a good fit, it's a bit of a luxury item for 1080p.
https://linustechtips.com/topic/1042455-help-needed/#findComment-12376764
