motherboard Chassis Fan header Amperage not given
I did a quick search on "Asus CHA_FAN maximum" and people owning various Asus motherboards report that theirs is 1A according to Asus' tech support. This matches the number that I've read from other brands. Looks like most (or maybe all) motherboard manufacturers put 1A SYS_FAN and CHA_FAN headers on all their motherboards.
As for how many fans you can connect, that depends on the fans themselves. There are fans that use 0.2 A, but also some that use close to 0.5A. Look up the specs of your fans, add the numbers up and try to stay below the maximum rated capacity of the header you connect them to.
If your fans and pump really draw more power than your fan headers can deliver, there are special PWM splitter cables that allow you to power the fans directly from the PSU whilst still getting the PWM signal from the motherboard. But for those you'll need 4-pin fans all around.
For example (Ebay UK link because that was the first one I came across) : https://www.ebay.co.uk/itm/GELID-Solutions-1-to-4-PWM-Fan-Splitter-Cable-Connect-4-PWM-fans-to-1-socket-/111785612920
You can get models that split to whatever number of fans, using either Molex or SATA power. (you may have to look a bit harder for the latter)
