I decided to overclock my EVGA 1070ti last weekend. I didn’t keep the overclock setting after playing with it so now it’s back at stock. I noticed this week I have a weird hum or buzz coming from my power supply when under load. I took it halfway out of the case and fired up a game to confirm it was the power supply. It’s a cheap 600W standard 80 plus certified from cyberpower. I don’t remember the name. My question is can overclocking damage a power supply? I’ve watched some videos on humming being an annoying but common thing. I just found it odd that it started after I started to overclock my GPU
https://linustechtips.com/topic/1042217-psu-starting-buzzing-after-overclocking-gpu/
Could be your mobo too , when i put my system under load sometimes my motherboard coil wines
Current main PC:
CPU: R7 7800x3d (PBO undervolted)
GPU: 7900XT
RAM: 32gb Gskill Ripjaws S5 6000mhz
MOBO: Asus TUF B650e wifi
CASE: Xtia Xproto ATX
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
RAM: Assorted 4gb sticks (24gb total)
MOBO: Asus Sabretooth X58
CASE: Alienware Area 51 ALX
1 minute ago, seriosbrad said:
Are you sure it's the Power Supply? It's very common for video cards to have "coil whine" under load.  My non-Ti 1070 does it, and I've had plenty of cards in the past do it. It's also harmless.
I’m almost certain. I took it about halfway out of the case and placed my ear right near the exhaust. I say almost Certain because I have a meshify c and the case isn’t know for quiteness. I did see in a vid that gpu’s did that as well, which is news to me. Just really curious if a power supply can be damaged from overclocking.
I didn’t know a motherboard could have a coil whine. I’m about 98% sure it’s the power supply
ok. (Some slightly older motherboards can have coil whine I am on the am3 platform and some am3 motherboards at least have coil whine)
Current main PC:
GPU: 7900XT
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
Current main PC:
GPU: 7900XT
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
14 minutes ago, SSTitan said:
I ordered a EVGA supernova 750 80 plus gold yesterday. I couldn’t really find an answer to my question so I decided to join and post here.
Which one?  EVGA has six different Gold PSUs.  Half of them will have the same problem.
22 minutes ago, SSTitan said:
The 750W EVGA G2 would have been a better choice, it's a much better UNIT, one of the most solid PSU's you can buy.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
