The gpu slot tab/lock got lost in the repairing time. I wonder how can I remove the tab below to get it to the top one which I intend to install a 3-slot graphics card. If you don't understand my poor English, plz look at the photo.
Or, could I install it in the middle one? It can barely fit cuz my card is 2.5slot, I am afraid the space/air for the 3gpu fans and PSU is not enough cuz of the tight space. PLEASE SEND HELP!
https://linustechtips.com/topic/1041581-motherboard-slots-problem/
i'm not an expert but i doubt you can move the locking tab. You said:
Did you attempt to repair something? Is this motherboard new and under warranty? What happened that led up to this?
Insanity is not the absence of sanity, but the willingness to ignore it for a purpose. Chaos is the result of this choice. I relish in both.
You don't NEED the locking mechanism, as long as you screw the video card in with screws. Would help if you don't have cables pulling down on the card.
The retention clip is there to lock card in place, in addition to the screws because some cases don't have screws there and rely instead on other methods of securing the cards which sometimes aren't so good.
I sent it to a computer repairing place and after it came back, it's like this.
Really? I mean I'm installing a monster, a 2080ti trio from msi, could 2-3 screws hold the card in place at the rear part?
ok this changes everything.
You march back down to that repair center and tell them that they broke your motherboard and they need to replace it for you because that's their fault
Be polite about it but yes, do this.
PC Specs:
CPU: AMD 1700x Cooler: Corsair H100i V2 Motherboard: Asus Crosshair VI Hero RAM: 4 * 8GB G.Skill RGB DDR4 Graphics: EVGA GTX 1080 Ti SC2 Storage: Samsung 960 EVO 500GB Case: Fractal Design Meshify C PSU: EVGA 750w G3 Monitors: Dell SG2716DG +  2x Dell U2515H
Freenas specs:
CPU: Intel Xeon E5-2650 V2 Cooler: Some noctua cooler Motherboard: Supermicro X9 SRL-F RAM: 8 * 8GB Samsung DDR3 ECC Storage: 6 * 4TB Seagate 7200 RPM RAIDZ2 Controller: LSI H220 Case: Phanteks Enthoo Pro PSU: EVGA 650w G3
Phone: iPhone 6S 32 GB Space Grey
You're a funny man man, I wish I could but that was half a yr ago.
Then your choice is either live without and hope the screw holds it in tight enough
or
buy a new mobo
Also don't go to that repair center ever again, nothing they could be trying to fix should involve them breaking a pci slot if they're even halfway competent
As long as you put the card in the slot correctly and screw it in at least 2 screws, it should be fine. I had a board that this happened to quite a while ago, and I continued using it. It's still in use to this day, no issues, just need to pay extra attention when installing graphics cards.
Primary Rig:
CPU: AMD 7800X3D @ Stock PBO - Mobo: Gigabyte X670E AORUS Master
2 x 48GB G.Skill Trident Z Royal 6400MHz CL32 1.35V @ 6200MHz CL28-37-32-30 1.5V (still tuning)
CPU Cooler: EK AIO that will be being replaced when I get the chance - PSU: eVGA P2 1200W
GPU: Gigabyte RTX 4090 Gaming OC @ either 2595MHz @ 900mV or 2970MHz @ 1070mV
Case: Thermaltake View 91 - SSDs/HDDs: 1 Samsung 980 Pro 2TB, 2 990 Pro 2TB M.2s, 1 990 Pro 4TB M.2, 1 TeamGroup Cardea Z440 2TB M.2, 1 Seagate EXO X10 10TB HDD
Monitor: Samsung Odyssey G9 49" Super-Ultrawide 240Hz Monitor
