How much room should I give my GPU's fans to properly cool it?
Solved by jorenc,
Enough room = yes. If you do vertical mount, it will run hotter, but unless your GPU is clocked to where every degree counts, you'll experience no issues whatsoever. Modern GPU's are great at handling heat. Even if it was pressed up against the tempered glass, you're not going to even get close to 70C.
Imo, the GPU down a slot looks worse than tubes pressing against a GPU in the top slot.
Listen to Luke, "Just do it. It'll probably be ok."
