So I'm going to eventually build a pc. However, it will be my first one ever. I was thinking if there were people out there who knew how to assemble pc's or if its better if I do it myself or idk,.....help? I live in southern california.
https://linustechtips.com/topic/1040511-help/
If you can build lego you can build a pc, just follow the instructions
https://linustechtips.com/topic/1040511-help/#findComment-12358236
https://linustechtips.com/topic/1040511-help/#findComment-12358246
20 minutes ago, DEEJAY said:
Abit more but you get a 100hz 1440p ultrawide monitor and an RTX 2080:
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor  ($379.89 @ Amazon)
CPU Cooler: Phanteks - PH-TC14PE 78.1 CFM CPU Cooler  ($82.00 @ Amazon)
Motherboard: Gigabyte - Z390 AORUS PRO WIFI ATX LGA1151 Motherboard  ($184.99 @ Amazon)
Memory: GeIL - EVO SPEAR 16 GB (2 x 8 GB) DDR4-3000 Memory  ($84.99 @ Newegg)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive  ($67.99 @ Adorama)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2080 8 GB WINDFORCE Video Card  ($706.98 @ Newegg Business)
Case: Fractal Design - Meshify C White TG ATX Mid Tower Case  ($79.99 @ Amazon)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($63.98 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($99.49 @ SuperBiiz)
Monitor: MSI - Optix MAG341CQ 34.0" 3440x1440 100 Hz Monitor  ($459.99 @ Newegg)
Keyboard: Logitech - G413 Carbon Wired Gaming Keyboard  ($65.95 @ Amazon)
Speakers: Logitech - Z323 30 W 2.1ch Speakers  ($44.97 @ Amazon)
Total: $2381.10
Generated by PCPartPicker 2019-03-03 22:31 EST-0500
https://linustechtips.com/topic/1040511-help/#findComment-12358292
This unit is fine for mass storage, so you know, this hard drive does not support workloads for 24 hours, it was designed to work on a normal workday of approximately 12 to 14 hours a day, if you need to leave the computer on for 24 hours then you will need the BarraCuda PRO version: https://www.seagate.com/internal-hard-drives/hdd/barracuda/#specs-3-5-pro
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/1040511-help/#findComment-12359810
