Audio interface question
Solved by dylandylandylan,
It's because I was planning to hook up two mics for a podcast type, and after researching, gives you a variety of mics need for different situations
I asked a similar question for a USB mixer the other day, and came to the conclusion that this one is pretty good, only two XLR inputs though; Behringer XENYX Q1002USB 10-Input, 2-Bus Small Format Mixer with USB Output.
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=945332&Q=&is=REG&A=details
