Need upgrading advice
Go to solution Solved by 3 Lions,
Try and find a used i7 4770K or i7 4790K on Ebay, as for the artifacts if you have the GPU overclocked drop it down slightly.
Hello, everyone. I was wondering someone could please give me some advice on what I should upgrade?
Budget: $1000 USD
I'll be using the PC for 1080p gaming on two 144hz monitors.(I use one for gaming, the other is for having other programs open) and school work.
Side note - I don't know if it's my GPU or another component, but I sometimes get artifacts in games followed by a lockup. All components are passed their warranty date.
Current build:
  • CPU
    Intel i5 4690k Devil's Canyon
  • Motherboard
    MSI Z97S SLI Krait Edition
  • RAM
    16GB Avexir Core Series DDR3 - 2400
  • GPU
    EVGA GeForce GTX 980Ti SC+ AXS 2.0+
  • Case
    Phanteks Enthoo Pro Series - White
  • Storage
    WD Caviar Blue 1 TB + OCZ ARC 100 120GB SSD
  • PSU
    EVGA 220-G2-0750-XR 80+ Gold 750W
  • Cooling
    CRYORIG H7
https://linustechtips.com/topic/1040384-need-upgrading-advice/
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12356994
$1000 is a lot, what were you looking to upgrade to performance wise? I think an i7 is very useful to you, used off eBay is a great value.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357009
If you have $1000 I would personally get a bunch of new parts, keep the cooler, PSU, GPU, case, and storage.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357025
I forgot to mention that the GPU isn't overclocked, it's stock manufacturer settings.
Well, I just wanted to get more performance out gaming. For example, in AC:Odyssey I average around 50-55 frames. Sometimes it'll dip to the 40's even when I'm not playing on the highest settings.
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357030
What would be the best combo of parts to get for that budget? I was looking into the Ryzen 5 CPUs, but then I am told a used i7 is more than sufficient,
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357035
Have you tried using another display output or another cable?
زندگی از چراغ
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357036
I mean a used i7 wouldnt be bad, but that's probably going to be a quad core. A quad core isn't bad but I would suggest getting a ryzen 5 2600, good b450 or X470 motherboard, and then getting a Zen 2 CPU later in the year.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357041
AC origins will like an i7, it helps to have more threads.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357044
Not necessary, his current system is fine apart from maybe a CPU upgrade on the same platform.
زندگی از چراغ
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357045
Yes, I was using a 32 in. TV previously and I was getting artifacts. Less than 2 months ago, I bought 2 new ViewSonic XG2402 monitors and I sometimes get the artifacts from time to time.
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357049
Is the graphics driver up to date?
زندگی از چراغ
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357054
Yep. Also, I have a question. Would an i7 4770K or i7 4790K still hold up in a few years?
Okay have you tried a clean install of Windows?
An i7 4770K or 4790K should be fine for at least another 3-4 years.
زندگی از چراغ
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357073
I've tried new installation of windows, I've redownloaded windows multiple times from the Microsoft page. I've tried underclocking, I've tried increasing fan speed. Reverting to older drivers, but it happens from time to time.
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357079
If it's only from time to time then I would personally not worry about it, if it gets to a point where games are unplayable then start looking for a new GPU though for a stock 980Ti to start suffering from faulty VRAM is basically unheard of.
زندگی از چراغ
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357089
So the lower FPS has nothing to do with the GPU?
Not really, the GPU is very capable.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357094
Thanks for the advice. I greatly appreciate it. I'll definitely stick with what I got and just upgrade the CPU.
https://linustechtips.com/topic/1040384-need-upgrading-advice/#findComment-12357119
