Could just be not great silicon, cpu overclocking is really luck of the draw. Does it have adequite cooling or is it overheating?
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
Are u changing voltage?
I am not familiar with the AsRock BIOS; could you share some UEFI screenshots?
I've got a i7-6800K (well..in the RMA process..long story) and a ASUS X99 Deluxe II.
Could do some UEFI BIOS setting comparisons with what you have set.
By the way, mind was running at 4.0 GHz as well.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
