So the short story is that I've never own a desktop pc for gaming and I've never built one so in December I decided to go for it. Now I'll be updating all day how things go and how is working even tho that just for now I'm not gonna start cuz in working.
SPECS:
Asus Rog B350-F Gaming
Ryzen 7 2700X
Hyper 212 EVO
Corsair Vengance 16GB RAM DDR4
Kingston 240GB SSD
1 TB HD
Nvidia RTX 2070 8GB
750w EVGA Power Supply
Corsair 200R.
It will be running on Windows 10 pro.
https://linustechtips.com/topic/1039239-my-first-rig-ever/
SPECS:
Ryzen 7 2700X
Hyper 212 EVO
Kingston 240GB SSD
1 TB HD
Nvidia RTX 2070 8GB
Corsair 200R.
Not a bad rig, But I have some questions
Why the Hyper 212 When the stock cooler looks cooler and runs the same for free?
What made you get B350?
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/1039239-my-first-rig-ever/#findComment-12347842
I have the same board, which is decent.
I have the same RAM, which has given me a ton of problems and nearly bricked my board.
I second @Killstreak, you could have used the stock cooler or gotten a better aftermarket cooler.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1039239-my-first-rig-ever/#findComment-12347858
corsair vengeance? never really heard about problems with those before did you return and get better ones, or you used different ram entirely
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/1039239-my-first-rig-ever/#findComment-12347904
I managed to make it work, and didn't have to RMA the board. In the future I'm going to avoid Corsair products in general, not the first time they've left me high and dry.
Basically, I couldn't boot past 2133Mhz with the second slot filled (I have 4x8), I eventually reflashed and reset the BIOS, tried all kinds of configs, and then eventually got it to boot at 2666Mhz. Then set DRAM voltage for 2.5v and DRAM frequency to 3000Mhz and got a POST. Still takes over 15 seconds to clear POST, but my mobo runs and my RAM isn't slow.
*GPU Test Bench*
https://linustechtips.com/topic/1039239-my-first-rig-ever/#findComment-12347914
That's weird, my cousin have the same RAM and he had never encountered any issue and I didn't know if the stock cooler was to going be enough even tho it has good reviews, besides all of that it's a $1300 gaming pc and it should easily run every game that are being launched this days.
https://linustechtips.com/topic/1039239-my-first-rig-ever/#findComment-12348766
SPECS:
Ryzen 7 2700X
Hyper 212 EVO
Kingston 240GB SSD
1 TB HD
Nvidia RTX 2070 8GB
Corsair 200R.
Good choices but ill say you can probably use the cooler that came with the cpu if you want.
https://linustechtips.com/topic/1039239-my-first-rig-ever/#findComment-12348826
 I watch some video on yt giving bad review to the stock cooler, I was just stupid lmao
https://linustechtips.com/topic/1039239-my-first-rig-ever/#findComment-12350822
well intel stock coolers suck. But amd is ok and their more expensive cpu have better fans. you can still use the 212 but we are just saying you dont need to
https://linustechtips.com/topic/1039239-my-first-rig-ever/#findComment-12351098
