Ethernet cable
Solved by Spotty,
4 minutes ago, Siddhant Mishra said:What should I check / expect to be present in a Ethernet cable before buying one? And what is this RJ 45/47 stuff going on .?
RJ45 is the connector type.
Inside the cable are 4 twisted pairs of copper wires. Brown + White&Brown, Green + White&Green, Blue + White&Blue, Orange + White&Orange. Either unshielded or shielded (foil wrapped). If it's for outdoor use it will have a waterproof gel inside.
Look at the different Cat ratings for the cable for its speed.
- Cat5 for 100mbps (100m)
- Cat5e for 1gbps (100m)
- Cat6 for 1gbps (100m) and up to 10gbps (~50m)
- Cat6a for 10gbps (100m)
