Because I want to led sync everything and there aren't other companies like TT that they have soft for sync and products I need (fans, water blocks, keyboards, mices and can be synced in one software). If I take products from multiple compaines I'll have to use Mystic Light which is shit as I said above.. :/
https://linustechtips.com/topic/1038927-thermaltake-ecosystem/#findComment-12344966
I haven't used too many of them, but if you want to LED sync everything you'd probably be best off using Corsair, or a dedicated RGB controller. you can also sync up the peripherals as well and it is nice to be able to cut down on like 27 programs to control RGB
Current Build
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
https://linustechtips.com/topic/1038927-thermaltake-ecosystem/#findComment-12344992
Stonowinnerz, there are upsides and downsides to both sides of this.  Getting the best peripherals (which I did) leads to having to use 4 different programs, 2 remotes, and my phone to change my system around.  Going with one "ecosystem" means not always getting the best parts.  It's a huge trade-off.  What I know is everyone loves ThermalTake parts, but hates their software (maybe this has changed).  I have to use Asus, Corsair, MSI, and PicTec software.  I got great cheap RGB fans, but they have a wireless remote.  Backlighting is another remote.  My RGB strip is controlled over WiFi.  I don't have a solid answer for you, as it is a conundrum.  You can either chose the best parts for you, and get prolly junk software, or use award-winning software that controls peripherals you aren't happy with.
An OVERALL recommendation would be to follow what Emanbird said, as they have a huge ecosystem, great parts, tons of control, complicated software, and are very expensive.
Edited by AsusMaximus
https://linustechtips.com/topic/1038927-thermaltake-ecosystem/#findComment-12345015
