Hello, recently i've been having problems playing fortnite and apex legends because my framerate kept dropping from like 200 to 40 fps. I have noticed on xtu that my cpu utilization keeps dropping from 80% to 20% everytime i have these fps drops. Any idea on a fix?
I've got a laptop, dell 7577 with an i7 7700k
https://prnt.sc/mqhv67
https://linustechtips.com/topic/1038396-cpu-problems/
It's generally not the CPU's fault when CPU utilization drops. If I had to guess it's an issue with asset loading. I assume you have Apex installed on the HDD? That's probably the issue. Whenever a texture or model loads in the game it needs to load from your hard drive that isn't quite keeping up.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1038396-cpu-problems/#findComment-12340765
Apex is installed on a hdd but it does the same thing to fortnite which is installed on my ssd
https://linustechtips.com/topic/1038396-cpu-problems/#findComment-12340778
running low on memory?
Desktop benching:
https://linustechtips.com/topic/1038396-cpu-problems/#findComment-12340780
Just now, iMDarker said:
i got 18.1 gb left in my ssd and 520 on hdd
memory = RAM, SSD & HDD = storage. I'm not talking about that
Desktop benching:
https://linustechtips.com/topic/1038396-cpu-problems/#findComment-12340803
