Ryzen 5 1600 & Corsair RGB PRO 2x8 3200mhz UEFI BIOS Utility Settings Help
Solved by Derrk,
37 minutes ago, Blinci said:Sadly it crashed with d.o.c.p standard 3200mhz at 1.35v. I’m not sure if I should maybe try tweaking manually, or worse case return it for a different pair. Not sure if it’s because of my Asus b350-f gaming mobo.
DOCP/XMP often need a little bit of tweaking before running perfectly stable. Things you could try are slowly increasing voltage, dropping speed slightly, or loosening the timings.
I'd first try increasing voltage, probably to around 1.375 and if that isn't stable, then bumping it to 1.4.
