I got some help with my first build last night and have a more finalzed idea. However I’d still like a little help mainly on the motherboard as im not as knowledgeable about them. This is the build I have going so far. I just need a board that fits well with my parts and I can add a hard drive to later on. https://pcpartpicker.com/user/left4donkeys/saved/YPFQZL
https://linustechtips.com/topic/1036925-updated-first-pc-build/
Get a Z390 Aorus board. You'll thank me later..
Seriously though, Asus is lacking quality boards this time around.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328520
From what I've heard, Asus 300 series motherboards are not that great. Though I would probably end up buying an Asus board anyways, I've always had positive experiences with their products.
I would highly recommend getting an i5-9600k instead of the 8700k. Both perform quite similarly at stock speeds, and the soldered IHS on the 9600k should theoretically give you better OC headroom. Not to mention, the 9600k is a lot cheaper, only get the 8700k if you actually need the extra cores/threads.
I would recommend a Seasonic Focus Plus Gold over a Corsair TXM, I believe the Corsair CXMs are also better than the TXM line. 750W is a little overkill, you could get a higher quality 650W unit instead and still be fine.
Excellent RAM choice, G.Skill is my fav RAM right now.
Excellent GPU choice as well. Asus Strix cards have been my go-to for good GPUs for a while now.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328522
I was looking into the i5 9600k for bit but I’ll take a second look. The power supply I was definitely thinking of going a bit lower since I don’t really need a ton of overhead on power.
The motherboard though I’ve just had a lot of issues deciding on what I like the one I have is more a placeholder for this.
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328534
Alright I’ll definitely be checking it out as an option. Even with 4 sata ports I think it was disabled because of the m2 slots in use I’ll have extra for hard drive expansions then right?
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328537
From what I've seen, most boards these days have 6 SATA ports and 1 M.2 slot. Typically, 2 of the SATA ports (labeled and mentioned in the manual) are disabled if the M.2 slot is filled. If you need all the SATA ports you would have to either get a PCIe riser with M.2 or bypass NVMe altogether (which NVMe isn't any better than a SATA SSD for gaming and generic tasks anyways).
*GPU Test Bench*
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328540
That’s what I was seeing with 6 being the average. Alright would you have a suggestion on a good SATA SSD then that’s about $80 or less?
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328547
WD Blue or a Kingston
*GPU Test Bench*
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328554
2 minutes ago, Left4Donkeys said:
Alright those are two brands I’ve heard good things about. One last question overcloking on the z390 is fairy easy then? If it is I think it’ll be the board I go with.
Z390 is OC enabled, and if you get a 'K' CPU all the settings should show up in the BIOS. Just make sure you know what you're doing.
I have a WD Blue 1TB 2.5" SSD. Great drive, even has faster writes than the Samsung 860 EVO 500GB in my main PC.
*GPU Test Bench*
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328570
Alright just wanted to be sure. I’ll probably do overclocking when I research how to more and feel more confident I won’t mess something up. I’m absolutely gonna look into the WD Blue then. Thank you so much for the help it’s extremely appreciated.
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328581
the Kingston SATA ssds aren't very good, at only $5 more i'd also rather get the EX900 over the WD blue 3d. not like he needs 5 sata ports anyway.
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328582
I wouldn't worry about it. You'll be fine with plenty of storage, SATA ports and M.2 slots..
As far as good SATA SSDs, Western Digital Blue, Samsung 860 EVO, Crucial MX500, are good choices for 2.5"/2280 M.2 drives.
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328587
The Western Digital Blue was looking pretty nice to me. As for the ports and slots I just wanted to be sure as I said I’m not as knowledgeable about motherboards so I just wanna to be sure about everything.
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328599
You'll be fine. Using just a SATA SSD in the M2 slot will not effect the GPU x16 slot or the SATA ports. Even using something like a 970 EVO or Wester Digital Black NVMe, you would be fine. You would probably only run into issues if you tried using an NVMe in all the M2 slots on the motherboard.. Which you wouldn't do anyway..
https://linustechtips.com/topic/1036925-updated-first-pc-build/#findComment-12328609
