Okay, so I've recently moved apartments however my ISP is being slow with activating my line, so I was wondering if I would be able to use my mobile as an ethernet hub too my pc.
I know you can connect your android devices to a modem etc through ethernet to connect to the internet but can it work in the opposite direction and if so how?
My 4g is spotty inside the flat so the plan was to leave my phone in an are with good connection (which is in another room) and run the ethernet from there to my pc
Thoughts?
https://linustechtips.com/topic/1036630-ethernet-over-usb-c-for-android/
I can get pretty reasonable speeds on my computer using my Google Pixel 2 as a wireless hotspot (assuming decent 4G reception), and I can get pretty reasonable speeds using a USB type C to RJ45 adapter to use my home internet over a wired connection to my phone, but I've never tried to provide my computer with a wired internet connection from my phone.
I'm not sure if it can be done. If I remember then I will try this later tonight when I get home from work.
Generally phones will have a wifi hotspot capability, but if you absolutely need ethernet that isn't an option. There might be a way to put a phone into bridge mode with an ethernet cable, but I don't know it.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
  • 2 weeks later...
