5 minutes ago, Ronix97 said:
I overclocked my R9 380x nitro to core clock +80, and memory clock +110 and temps go to 77 celcius, is that okay temperature?
Its a tiny bit high, but ultimately yes it should be fine. Well, as long as those are your temps while under load.
AMD cards from those generations tend to be a little toasty mind you.
Max operating temps for that card iirc should be about 95c, so you have plenty of room, but personally i wouldnt want it to go above 80 like, ever.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/1036600-normal-temps/#findComment-12325428
