I have a pair of Apple's lightning earpods that came with a friend's iPhone and he got Airpods so he gave them to me. I have an Android and I can't connect these earpods to anything. Is there any possible way to connect lightning earpods to micro USB? Thanks so much!
https://linustechtips.com/topic/1036528-lightning-earpods-on-android/
Wait wait, to micro USB? Does your phone has a micro USB port and no headphone jack?
Because if you can convert to 3.5mm that's better, just get a regular dongle (if he has iPhone X or older he should have one)
I once gave Luke and Linus pizza.
Proud member of the ITX club.
**SCRAPYARD WARS!!!!**
#BringBackLuke
Is it even possible to use Lightning EarPods in 3.5mm jack port?
I bought 3.5mm jack EarPods thinking they are the same as Lightning ones, but they are garbage compared to Lightning EarPods in terms of bass. Which sucks. But if there is an adapter from Lightning to 3.5mm jack, I'd be thrilled.
