Hello. Today I installed GPU-Z on my computer. I loaded up Mirror’s Edge Catalyst and played for a few minutes. Then I checked GPU-Z and in the row that says why your GPU is underperforming, I saw 2 problems. The first one was marked as Vrel and the second one as Thrm (or something like that). But I don’t really know what those things stand for. Could someone explain what those things mean?
https://linustechtips.com/topic/1036294-gpu-z-problems/
By the way, should I do anything if these problems are dangerous?
https://linustechtips.com/topic/1036294-gpu-z-problems/#findComment-12322687
screen shot of gpuz?
Main Rig
CPU: i7 3770K@4.7GHz
GPU: R9 290x 4G
HDD: 12TB Seagate 12TB BarraCuda
SSD: Crucial xm500
RAM: 4 GB DDR3 XPG 1600 x4
Monitor: Dell U2518D
Server
CPU: duo Xeon X5670 stock clock
Motherboard: unknown dell server motherbored
RAM: 64GB of unknown ECC 1600MHz ram
GPU: Nvidia Quadro P4000
HDD: x8 Dell 2.5inch SAS drive in raid, potenal speed of 800MB/s speed
SSD: NON
Case: Dell unknow server case
PSU: duo 700w server powersupply
Works laptop:
Model: Microsoft surface laptop 3
CPU: i5 1065g7
RAM: 8gb lpddr4x
Dongle: satechi aluminum mutiport adapter v2
SSD: 256gb stock
Comment: best laptop on my lap
I suck at writing this.
https://linustechtips.com/topic/1036294-gpu-z-problems/#findComment-12322715
no they're not dangerous, this is completely normal.
Vrel basically means the card is limited by voltage which is fine because they are limited by the voltage that they can go up to, so it's like a "duh" kind of error.
Thrm is related to thermals but i have no clue how that works, it would be nice to know your maximum temps, but usually it's also normal to see this even if your temps are low.
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1036294-gpu-z-problems/#findComment-12322728
it's also best to ignore Perfcap Reasons and focus on the boost clocks that your card achieves during gameplay, and the temperatures, if the clocks and temps are normal then everything is fine.
If your card is under performing then you can go look at the Perfcap Reasons, it's mostly a tool for troubleshooting, not to check if it throws errors even when everything is running normally.
https://linustechtips.com/topic/1036294-gpu-z-problems/#findComment-12322735
The max temperature was 82C.
https://linustechtips.com/topic/1036294-gpu-z-problems/#findComment-12322782
Voltage regulation. Very normal. Turn all the power and voltage to max. But the fact it’s thermal throttling, need to cool the card down.  All sinple stuff.
https://linustechtips.com/topic/1036294-gpu-z-problems/#findComment-12322785
Also, how do I cool my card down? When I put a fan curve on it, it makes a very weird sound (like something is loose or broken). Is there any way to cool it besides a fan curve? My GPU is a blower.
https://linustechtips.com/topic/1036294-gpu-z-problems/#findComment-12322858
New paste perhaps. Fan on max is the only way. Swapping the cooler, under powering it as well.
https://linustechtips.com/topic/1036294-gpu-z-problems/#findComment-12322881
12 minutes ago, Premilix said:
Would water cooling my GPU help? For example the Ekwb A240g kit?
Absolutely. Best case scenario. Can cut those temps in half. Increase the clock speed quite a lot stock as well.
https://linustechtips.com/topic/1036294-gpu-z-problems/#findComment-12322979
