Hello, I'm planning to do custom watercooling in the node 202, looking for feedback on my ideas. To start, I'm not sure whether to use a mini GPU with a 120mm radiator or a normal sized GPU with a slim 240 and slim fans. Thoughts on this? The actual hardware isn't really decided yet, I have lots of parts and I could go either Intel or AMD. I do already have the case and an SF600 Gold, planning on custom ordering from cablemod for the exact cable lengths I'll need. I was also thinking of modding the top of the case and putting in a tempered glass panel so I can see inside. For this reason if I go with the mini gpu/120mm rad I'll probably need to custom cut a gpu backplate. For the pump/res I was thinking I could find a small res to fit in the corner behind the psu where 2.5" drives go (i'll use an m.2 for storage) and maybe one of those combo pump/cpu blocks. One thing that I know I don't want to do is have an external res, pump, or anything. I'd like to keep it all inside of the case.
At this point I'm just at the drawing board, so any ideas or feedback is welcome. Thanks for taking a look.
https://www.reddit.com/user/scarlet_shade/
Main PC: (custom waterloop)
Threadripper 1950X @ stock
8x8(64GB) Corsair Vengeance RGB Pro @ 3000mhz
Asus Prime X399-A
2x EVGA 980 Ti Classified w/ EK Waterblocks (SLI)
Corsair AX1200 w/ White Cablemod
512GB Samsung 850 Pro
512GB Intel 600p M.2 NVME
NZXT H700i White
'Media' PC:
i5 8600k @ 4.9GHz
Corsair H80i 120mm AIO
16GB TridentZ @ 4133mhz
Asus z370-i Strix ITX
EVGA GTX 1070 Ti FTW2
Corsair SF600 SFX PSU
256GB SL308 SSD
500GB WD Blue SSD
Thermaltake Core V1 ITX Case
https://linustechtips.com/topic/1035929-node-202-watercooling-project/
there was a guy who did it on this forum already, here is what he did:
There is also a more recent one here, but its not as impressive or detailed:
Builds:
It is probably better to do a plexi glass panel with some king of perforation (ventilation) on top of the case, you will need hot air to exhaust somehow. Perforated tempered glass will cost you an arm and a leg.
Due to size of the case it is best to use something like a ddc pump
As for gpu you can use 1080mini from gigabyte or 1080mini from zotac if you want to do a high end build. (Barrow and byksi makes waterblocks for them)
in any case it is a very chalanging build
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
