Should i watter cool it or not. Help needet from watercooling people
By
rezixxx
in Build Logs
in Build Logs
Solved by Oshino Shinobu,
I would like to watter cool the CPU too, but my hart is hurting becouse i wasted money on that CPU cooler. (this PC is 3 months old)
Well, seeing as watercooling isn't essential, you may as well save for another GPU if you want one and then save up for watercooling after that so that your CPU cooler gets a decent amount of usage before replacing it.
Featured Topics
5
40
kasdashd ·
Edgar R. Zakarian ·
Posted in CPUs, Motherboards, and Memory7
