I am almost done with my system. I only need two things to start using my new computer, a graphics card, and Windows 10 (yay!). I will have about $500 to spend. I will have about $300 to spend since I am buying a key from Microsoft. For that price, what should I choose? If I can get one, should I get a Vega 56, or a GTX 1070? If not that, should I buy the RX 580/590 or a GTX 1060? I could wait to see what Navi has to offer but I would like to finish my system soon. I hope I can find a good deal on a new card or maybe even a used card. although I would prefer new. Anyways, open to suggestions. I will list my system specs if that helps:
Ryzen 5 2600, 12GB Mixed RAM, 750 Watt Power Supply, 1 TB Hard Drive, 128 GB SSD, Phanteks Enthoo Pro Full Tower.
https://linustechtips.com/topic/1035146-graphics-card-recommendation/
What monitor are you using?
Also, save some money and get windows off ebay for a few dollars
Grab a 580 for 150 bucks.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Why would he do that when that's only half of what he has to spend?
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
Right now a really old cheap TV from 2008 that's probably 720p. I know, yikes. But I may be using a newer 32 inch TV or I may just buy a 1440p Monitor, but I don't know yet...
I also feel more comfortable buying a new key from Microsoft, but I may look into it on eBay...
For that price range on a GPU go with whichever you find for cheaper between the Vega 56 and the 1070. If you can't find either of those in your price range get a 580 instead of a 1060.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
You can get Windows 10 product keys cheap off ebay and other sites, OR you can run it totally free (just means you have an "activate Windows" watermark and can't use personalization options. Which you can still personalize Windows by using other methods anyways).
I'd take your entire budget and spend it on a GPU. I would get a 2060, otherwise get a 1070 since those are fairly comparable to a 2060.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
Thats why
1 minute ago, Slottr said:
Thats why
$10 on Windows key.  Hell, I'll sell you one for $20 :)
$150 max for a monitor, $350 for GPU. 2060 6GB and a decentish monitor.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
4 minutes ago, Slottr said:
Thats why
Well, if he's planning to get a new monitor, it'd make sense to make the upgrade preemptively.
Main PC:
Peripherals/Other:
I know the appeal of using cheap windows keys but I came to the conclusion that it's something I am not very comfortable trying seeing the risks. I could use the Windows Installer and just use it for free for a while or indefinitely. That would be an option for me.
The sellers on eBay will usually give you a new key if one is bad. I've bought 3 Win10 Pro Keys for $7 or so each, only had one go bad but I couldn't be arsed to ask for a replacement since I didn't really need it right then, so $21 for two Win10 Pro keys that would be $400 retail is a pretty damn good savings. You'd have to get a lot of bogus keys before you came close to the price of windows 10 retail. Pretty scummy of MS to try and run Windows 10 as a service and collect your data but then still charge $120-200 for keys for consumers.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Yeah, I wish Windows 10 was like Android, free and open source... but nope...
I am afraid of grabbing a key that was bought with a stolen credit card...
Just use it free for a while and purchase a key off the Windows Store later on when you have more money saved up, or find a way to hide the watermark for good and bypass the whole system.
*GPU Test Bench*
What happens if you do?
OnePlus Ecosystem:
3D Printing:
That is something I would be willing to do. What is good for about $500 since taxes are an issue. Let's say $450ish?
For a GPU? I'd look at 2060's, those should only be around $350-389.
edit: Here's an example: https://www.amazon.com/EVGA-GeForce-Gaming-Graphics-06G-P4-2061-KR/dp/B07MJDBTD6/
*GPU Test Bench*
I am pretty sure you're key can get revoked and also accepting stolen goods (knowledgable or not) is likely considered illegal if they find out who you are. I don't want to run that risk.
They're usually OEM keys, I assume they buy them in bulk then resell them or whatever. I haven't had any issues with mine on my main rig or laptop or whatever PC I happen to sign into, it's linked to my MS account and activates exactly like Windows is supposed to, it's rather nice.
Mouse: EVGA X17
Key can get revoked, sure.  Accepting stolen goods?  Uhm.... nm.  Buy your Windows key and keep your peace of mind.  :)
OnePlus Ecosystem:
3D Printing:
i suggest you to save 60$ and buy cheap RTX 2060. Best in this price range probably is Radeon 590 but cheaper 580 is much better pick because it have very good performance per dolar ratio.
And 7$ Windows keys are not legal... do you guys love paying for pirates?
2
Yeah, 2060 looks like a good option. Thank you!
I am keeping my options open so I may go ahead and buy a lower end card and Windows but I may just use Windows free for a while and buy the key later. I am considering options I haven't thought of before so this is good.
I could go to about $330 on graphics and $140 on Windows Home if I do $500, plus maybe a bit extra in change. This is considering taxes which is 6.25%
