Hello, recently my CPU has been running very hot around 85-100 C with 0-10% load. I have been doing some sketchy stuff so I don't know if this is like a bitcoin miner or what. http://munchyman.club/images/CAM_aVg2CaxgIe.png - CAM Data
CyberpowerPC - https://pastebin.com/ntW4SMts
https://linustechtips.com/topic/1034667-cpu-running-hot/
That would have high usage... Are you running an AIO/Liquid Cooler?
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1034667-cpu-running-hot/#findComment-12308467
What kind of cooler are you using? If it's an AIO then, that's probably a dead pump if the temps were fine before.
Make sure to quote or tag people, so they get notified.
https://linustechtips.com/topic/1034667-cpu-running-hot/#findComment-12308481
ohhhhhhh.....
Pump failure. 100% the issue.
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1034667-cpu-running-hot/#findComment-12308482
2 minutes ago, MonkeyManofLife said:
How do I fix pump failure? I bought this as a pre-built from cyberpower.
Do you know the full specs of the machine? It might not even use an all in one liquid cooler.
Since you got it from Cyberpower you could call up their support and ask for help or, get it repaired if it's under warranty.
https://linustechtips.com/topic/1034667-cpu-running-hot/#findComment-12308546
https://linustechtips.com/topic/1034667-cpu-running-hot/#findComment-12309242
51 minutes ago, MonkeyManofLife said:
Yeah, you have a liquid cooler on there. Ok so, when did it start overheating?
If it did from the start then, maybe the pump's cable got loose during shipping, in that case replugging it will fix your issue but, if you have been using it for a while then, you most likely have a dead pump.
If you still have warranty on the system then, contact Cyberpower and ask for a replacement.
https://linustechtips.com/topic/1034667-cpu-running-hot/#findComment-12309453
I think it's been doing this from the start. How should I go about plugging in the pump cable? I've never done this kind of stuff before.
https://linustechtips.com/topic/1034667-cpu-running-hot/#findComment-12309466
You could remove the left side panel and check if the pump's cable is properly plugged in. Before doing so make sure to turn the PC off completely and unplug it from the wall as well.
Now, since they are using a custom Motherboard I can't really pinpoint the pump header's location so, you'll have to find it yourself but, it's usually near the top of the board.
It will have something like Pump_Fan written under it like this:
You should have a cable going from the CPU cooler that's plugged in there. If it is there then, make sure it's plugged in all the way.
If you need more help than that then, some pictures of the inside of the case would be helpful.
https://linustechtips.com/topic/1034667-cpu-running-hot/#findComment-12309521
If you can post some pictures of the inside of the system we might be able to see if there's any obvious issues. Could be the pump isn't plugged in, could be a dead pump. If it's a dead pump, you'll have to contact Cyberpower and have it fixed under warranty.
Does it have high Temps even in Bios? Can you check I'd the cpu fan/pump is showing any rpm/liquid movement if they have that enabled in bios?
Primary Rig:
CPU: AMD 7800X3D @ Stock PBO - Mobo: Gigabyte X670E AORUS Master
2 x 48GB G.Skill Trident Z Royal 6400MHz CL32 1.35V @ 6200MHz CL28-37-32-30 1.5V (still tuning)
CPU Cooler: EK AIO that will be being replaced when I get the chance - PSU: eVGA P2 1200W
GPU: Gigabyte RTX 4090 Gaming OC @ either 2595MHz @ 900mV or 2970MHz @ 1070mV
Case: Thermaltake View 91 - SSDs/HDDs: 1 Samsung 980 Pro 2TB, 2 990 Pro 2TB M.2s, 1 990 Pro 4TB M.2, 1 TeamGroup Cardea Z440 2TB M.2, 1 Seagate EXO X10 10TB HDD
Monitor: Samsung Odyssey G9 49" Super-Ultrawide 240Hz Monitor
https://linustechtips.com/topic/1034667-cpu-running-hot/#findComment-12309888
