Hi guys, new to the forum... Not new to building PCs.
I'm having an issue with my Asus Prime B350 Plus mobo. Whenever I pull the plug from my PSU and the motherbaord loses power (usually to move my PC, or adding hardware), and then putting the power back in, the red LED lights from the motherboard comes on... All is fine. Then I press the power-on button, motherboard and all the fans switch on, and right back off again... Then on again and pc starts up nomally withou issues. What could this problem be?
Note: I have a 650w PSU, AMD Ryzen 5 2600, Adata 8gb 3000MHz DDR4, AMD Radeon R7 370 2GB, Adata 128GB SSD and 3 more 500GB HDDs.
And I have tried a different PSU and GPU.
Any advice will be appreciated.
https://linustechtips.com/topic/1034527-motherboard-problem/
recovering from possible power surge? That sounds like how Asus' anti-surge system works
Desktop benching:
https://linustechtips.com/topic/1034527-motherboard-problem/#findComment-12307532
Normal double boot, probably checking memory. Don't worry about it.
https://linustechtips.com/topic/1034527-motherboard-problem/#findComment-12307533
