Hello to everyone,I got quick question here:
My sister bought me rtx 2080 asus strix gpu and as I guess it's not an OC version,returning it back will be serious pain in the ass,so I'm interested if this gpu can be overclocked manually and safely to the levels of OC edition?
I was worried that I will get card with 1710mhz clocks and non A chip. My aim was to buy at this moment something powerful enough for a couple of years,so I wanted it to have some OC potential... Would you be so nice and check photo I've attached? If with the "worst" strix 2080 I can get good OC anyways,I can have that card on my hands in about 1 week when my sister visits me from another country or she can return it and I can get some OC version by myself in a couple of months or so...
GPU - R9 390 Nitro   ///   CPU - Intel 3570K   ///   RAM - G.SKILL Ripjaws X Series 8GB (2 x 4GB)   ///   HDD - 3TB + 1TB / SSD - Crucial MX100 256GB
PSU - EVGA 750 G2   ///   Case - be quiet! - Silent Base 800   ///   Corsair A70 Cooler
https://linustechtips.com/topic/1033665-return-or-not/
First off, i want your sister to be my sister.
Second, You more than likely won't notice the difference, unless you look at it as an extra ~100mhz worth the return and upgrade with your money! I hope this helps. Plus just use MSI's afterburner. It works well with the auto overclock RTX cards
@Temuka
PC Set up
CPU: I9-9900k
Mobo: Gigabyte Z390 Aorus Pro-Wifi
GPU: MSI RTX 2070 Gamin Z
Cooling: Cooler Master ML360R AIO
RAM: Corsair Vengeance Pro RGB 16 GB 3000MHZ (8GB X 2)
RAM: Corsair Vengence Pro Lighting Enhancement Kit (0GB X 2)
Storage: Samsung 860 EVO 1TB
PSU: EVGA SuperNova G2 750 W 80+ Gold Fully Modular
Case: CoolerMaster MB511 RGB
Build Log found here:
https://linustechtips.com/topic/1033665-return-or-not/#findComment-12300188
The strix cooler is good and generally the GPUs are binned higher so you should be able to get some more performance out of it with an OC.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1033665-return-or-not/#findComment-12300219
Enjoy your new card and don’t worry about the overclock. I’ve got a strix 2060 and it’s been great so far, I can only imagine running a 2080 would be awesome
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1033665-return-or-not/#findComment-12300220
@Temuka
Haha,nice one,we are paying 50/50 :)))
Thing is that I won't upgrade any time soon and for this money we just wanted tu buy the best one ))) Can I get oc versions clocks with ocing it manually?
https://linustechtips.com/topic/1033665-return-or-not/#findComment-12300221
yeah for sure. I have a RTX2070 and I get 1950+mhz. Its not worth the headache trust me
PC Set up
CPU: I9-9900k
https://linustechtips.com/topic/1033665-return-or-not/#findComment-12300300
Yeah but non oc version is 1710mhz and oc version is 1890,almost 200mhz difference is a lot :(
https://linustechtips.com/topic/1033665-return-or-not/#findComment-12300562
Whats the price difference? Performance per dollar its probably not worth it. Its not that much man!
PC Set up
CPU: I9-9900k
https://linustechtips.com/topic/1033665-return-or-not/#findComment-12300594
you can oc it with afterburner to at around 1950, the difference on the max oc might be as little as 2% in actual gaming performance, just keep the card.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1033665-return-or-not/#findComment-12300609
just because it's not the "OC" model doesn't mean you can't OC it, it just means that ASUS's internal binning couldn't reach the standards they have for the OC variant of the card, you won't know the difference in the real world, at that point it's specs on a sheet of paper for which card left the factory with the higher preset OC.
https://linustechtips.com/topic/1033665-return-or-not/#findComment-12300946
