Audio and video desync at 24 bit
Swesaera
I just got the Massdrop x Sennheiser HD6XX and have audio quality set to 24 bit, 48000Hz and ever since I got them, audio has started to desync with the video I'm watching.
I mostly watch Twitch streams and after like 10 minutes the audio ends up playing 1 second before the video does and it progressively gets worse. This happens with youtube videos too.
Is there any fix for this?
I wouldn't set the audio to 24b unless the content you are listening to is specifically designed for that audio format.
this problem sounds unrelated to your headphone choice or sound settings.
Its just that it only started happening since I got the headphones, was fine with my old Logitech ones
