So here is my current config:
Ryzen 2700x OC to 4.25ghz
Corsair H150i to cool.
Corsair Dominator DDR 4 3200 OC to 3533mhz
Asus ROG Crosshair Vii
Gigabyte 2080 Windforce 3 OC 2040mhz boost and memory OC to 8000mhz
Samsung 970 PRO M.2 500Gb
WD Black 1TB
EVGA Supernova G2 1000 80= Gold
Thermaltake View 71 Case
and plenty of fans (11)
I want to push more do you think this will work or pointless.....
https://www.ekwb.com/custom-loop-configurator/shared/oW5c60d5aa0995a
I have around £800/€915/$1000 to spend. Should i go for it for more OC or stick and spend on something else?
https://linustechtips.com/topic/1032265-going-all-out-bttw/
4 minutes ago, HeNdEr said:
RAM cooling is not getting you anything apart from looks, and honestly youll only see a couple of degrees improvement from the 360 mm radiator.
The only thing thay would be "worth it" in my opinion is if you put your gpy under water.
https://linustechtips.com/topic/1032265-going-all-out-bttw/#findComment-12286968
