4 minutes ago, SHG_Marsh said:
IS there a way to find out how many watts my PC is using? I want to get new parts but i don't know if I need to get a new power supply. I am not planning on changing my CPU/GPU right now but new fans,motherboard, etc. I currently have a 450 watt power supply.
Corsair i Series of PSUs will alow you to use iLink and look at the PSU wattage usage among other things like temp or fan etc.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1032142-pc-power-usage/#findComment-12285902
14 minutes ago, SHG_Marsh said:
I have a gigabyte GPU
You will be using about 300 to 400watts when gaming.  At idle you will be at 130watts avg.
https://linustechtips.com/topic/1032142-pc-power-usage/#findComment-12286003
What parts do you currently have? What model CPU & GPU?
What parts are you planning on upgrading?
Which 450w PSU do you have? Should have a model number printed on the label on the side of the unit.
https://linustechtips.com/topic/1032142-pc-power-usage/#findComment-12286556
Ah, yes, with a Gigabyte GT610 and a G3240, he'll be drawing 300-400W at load, and 130W at idle... No. Without knowing the specs, you can't tell what the power consumption will be.
https://linustechtips.com/topic/1032142-pc-power-usage/#findComment-12286705
Your right seon123, totally right.  However Im taking into case, the different computers at work and the fun we had on them and my own experience with stats to show for it.  My rig in the sig is like 160 watts idle once you use it it will get close to 200watts,, worth case Ive seen is like 240 watts I believe.  Once you play a game its using like 400 watts plus!!!
https://linustechtips.com/topic/1032142-pc-power-usage/#findComment-12286722
With the G3240 and GT610 we're talking about something in the region of 100W, maybe 150W.
300-400W is with High end GPU and CPU.
Something like GTX 780ti, HEDT and/or high OC.
Stuff like that.
But with such a low end System, never ever. You can power like 3 of those with that power.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1032142-pc-power-usage/#findComment-12287277
@seon123 was being sarcastic, responding to the other person who said that the system would use 300-400W under load and 130W when idle - without knowing what parts the OP has.
OP hasn't told us what parts he currently has. Though looking at his profile, looks like Ryzen 5 1500x + RX 560 with an EVGA BT 450w.
Quote
System
  • CPU
    ryzen 5 1500x
  • Motherboard
    MSI b350m gaming pro
  • RAM
    Patriot Viper Elite 8gb ddr4
  • GPU
    radeon RX 560
  • Case
    NZXT S340
  • Storage
    120gb Kingston SSD/1tb WD Blue HHD
  • PSU
    EVGA BT 450
  • Display(s)
    Sceptre C248W-1920R
  • Cooling
    Fans
  • Keyboard
    Corsair K55 RGB
  • Mouse
    Corsair Harpoon RGB
  • Sound
    HyperX Cloud Stinger
  • Operating System
    Windows 10 Home 64-bit
  • PCPartPicker URL
If you're just replacing the motherboard or changing case fans then wattage won't be an issue.
https://linustechtips.com/topic/1032142-pc-power-usage/#findComment-12287299
Oh, yeah, I knew that, still thought it might be a good idea to tell people who don't know much about Power Consumption, how little that system might use.
https://linustechtips.com/topic/1032142-pc-power-usage/#findComment-12287512
