I just set up my first build and it’s getting too hot. Im using an ML240L on an Asrock z390pro4. It’ll idle around 70 and hit 110 before I shut it down or it does itself. I applied a pea of thermal paste and made sure the plastic isn’t on the mount.
I don’t think the pump is on, anyone have any similar issues/fixes?
Connections:
Pump-> CHA_FAN/WP
Pump-> RGB stuff -> CP1_FAN1
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/
You have the RGB header plugged into the CPU fan header? I don't think that's how it works... Take that out and leave the pump header plugged in. Feel the block/tubes, are they vibrating? Also you didn't say what CPU you have.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12283642
Is it screwed on properly?
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284022
I have an i5 9600k. They don’t feel like they’re vibrating. I have the one that comes from the two fans plugged into CPU_FAN1
I’m pretty sure
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284204
I’m pretty sure
try give the pump a wobble
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284215
The pump should be plugged into CPU_FAN1
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284236
you have the radiator fans plugged into cpu_fan1 funny af, read the motherboard manual if you're not sure.
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284274
It only has the cpu fan 1, which I have the pump plugged into and the other one into cha_fan 2/wp.
I looked in the manuel, but it only says to plug fans there and to match certain wires
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284326
fair enough is it working now though?
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284337
It’s still hovering around 85 when idle
I feel like the pump must be jacked up, I’ve tried pretty much all ports and different applications of thermal paste.
We have shitty postal service here, I wouldn’t be surprised if it got jacked up in the ride here hahaha
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284349
have you got a molex to 3pin adapter?
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284361
are the radiator fans getting power?
https://linustechtips.com/topic/1031865-ml240l-cpu-too-hot/#findComment-12284363
