What temperatures do you guys experience when idle and under load?
My fluid temperature is roughly 32c idle and 39c under load, are these within reason and will it affect the lifespan of my pump and/or radiator?
I read elsewhere on this forum that below 60c is within spec, however I'm just looking for reassurance.
I'm using an EVGA CLC 240, cooling a de-lidded, copper IHS'd i7-7700k at 4.9GHz on all cores.
i7-7700k | GTX 1080 Ti | 32GB 3100MHz | Prime Z270-AR
https://linustechtips.com/topic/1031634-aio-fluid-temperatures/
That's fine.
As long as it's below 50-60°C there is no worry.
And it's not the pump or rad that's the issue at those temps, it's the fluid itself.
Once you go over that 60°C the protrusion goes up a LOT. What happens is that the tubes expand slightly and water escapes through the tubes. In normal AIO's it happens constantly as well but it's such a small amount it's not a problem. That's also why there are small reservoirs in AIO's.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/1031634-aio-fluid-temperatures/#findComment-12281903
Just now, samcool55 said:
That's fine.
Thanks for the response, so should 38-42c under constant load be okay in the long run? I'd ideally like to keep the fans on my radiator quite low due to noise, and when at the minimum RPM, those are the temperatures I experience.
https://linustechtips.com/topic/1031634-aio-fluid-temperatures/#findComment-12281909
Yup, that's perfectly fine. Nothing to worry about.
https://linustechtips.com/topic/1031634-aio-fluid-temperatures/#findComment-12281917
