Lack of sharpness on text (24 inch 1080p monitor)
VirtualBlack
I recently bought a new monitor, is an LG 24MP59G, the 24 inch version, but i feel like the text is a bit more blurry than my old monitor, i upgraded from a HP 21 inch monitor
I think is due to pixel density, is there a way to solve this by software or should i return it?
4 minutes ago, PrinceNorris said:
Check if you are running at native resolution in Display settings and latest GPU drivers.
I did, maybe i am sitting too close to the monitor? i am like 40 centimeters from it
1 minute ago, PrinceNorris said:
I would consider around 50-75cm as 40 is very close. Check the refresh rate. What cable are you using?
A generic HDMI cable
