I'm upgrading my PC and want a new case soon becuase the CiT Vantage is the death of me. Can you folks link or name Cube or Flat style cases Just because I like them they'd to support ATX Motherboards, either a H80 or Seidon V120 and probably 2 GTX 760's. I know about the normal ones the Corsair Air 540, all the Cubitek ones. Thanks! :)
PC; CPU: AMD FX-6100 3.3Ghz Akasa X4 Cooler - GPU: GTX GeForce 650Ti 2GB Palit - RAM: 16GB 1333Mhz Team Group Inc - HDD: 7500RPM Barracuda 500GB - PSU: G7 Extreme Power 780w PSU - KB & Mouse: Víglen Mech KB Acer Blacks - Logitech MX518 Mouse (1200 DPI) - Laptop; Dell M5040 Mobile Phone; Doogee Voyager DG300
https://linustechtips.com/topic/103071-cube-case/
Well if I understood you right (nothing wrong with the way you write I am just tired ;) ) this should fit you well :)
http://www.coolermaster.com/case/lan-box/haf-xb-window/
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/103071-cube-case/#findComment-1378864
What are you looking for exactly ? Do you just want a case that sits flat on desk like a media center case. Or do you want a dual zone case like the air 540 or hafxb which has lots of space behind motherboard tray for drives and power supply ?
Main Rig: http://linustechtips.com/main/topic/58641-the-i7-950s-gots-to-go-updated-104/ | CPU: Intel i7-4930K | GPU: 2x EVGA Geforce GTX Titan SC SLI| MB: EVGA X79 Dark | RAM: 16GB HyperX Beast 2400mhz | SSD: Samsung 840 Pro 256gb | HDD: 2x Western Digital Raptors 74gb | EX-H34B Hot Swap Rack | Case: Lian Li PC-D600 | Cooling: H100i | Power Supply: Corsair HX1050 |
Pfsense Build (Repurposed for plex) https://linustechtips.com/main/topic/715459-pfsense-build/
https://linustechtips.com/topic/103071-cube-case/#findComment-1378875
Yes, I want a Case that seperates the PSU & Cables to the Motherboard. The HAF XB looks like the perfect choice.
https://linustechtips.com/topic/103071-cube-case/#findComment-1378922
Yes, I want a PC that seperates the PSU & Cables to the Motherboard. The HAF XB looks like the perfect choice.
The haf xb is awesome and i do own one. Just keep in mind that with this case I would only recommend using a 120mm radiator. You could put a 240mm in the front but then you loose the cool air coming in to feed your graphics cards. The case is a dream to work with if you like to swap out and tinker with stuff alot. Also super neat cable management.
IMG 20130602 192907 (1)
https://linustechtips.com/topic/103071-cube-case/#findComment-1378948
It's a very flexible case for AIO water cooling and very tall air coolers also on a less serious note short circuit by daft punk was playing when I saw your profile gif and I completely lost my shit.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/103071-cube-case/#findComment-1378962
I'm glad you enjoyed the mixture of my profile picture and Daft Punk. :)
Yeah I've seen people with custom watercooling in this case and I love it! I'm DEFINATLEY getting this! And I feel (I know it don't make a difference) that motherboards were intended to lay flat not at a 90 degree angle.
https://linustechtips.com/topic/103071-cube-case/#findComment-1379129
Yea, i also use that case for lan parties and i feel much safer with my video cards being transported on the flat motherboard vice hanging from an upright motherboard.
https://linustechtips.com/topic/103071-cube-case/#findComment-1379182
