I need help, I need to find some type of App/software to lock down my daughters android phone.
The wife wanted to get her a phone, and need a way to block calls. I found Qustodio but wanted to know if there was a free or close to free on out there?
I need to be able to locate her, and block call is the main thing.
Any help would be great.
https://linustechtips.com/topic/1030182-prenatal-control-help/
8 minutes ago, campy said:
>prenatal control
I cried
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
https://linustechtips.com/topic/1030182-prenatal-control-help/#findComment-12269170
https://www.google.com/android/find you can use this to locate any android phone
You can use "Should I Answer?" to block all incoming calls not stored in the contacts (in that situation all you have to do is not store numbers in the contacts), but you have to make sure you set it to do so in the settings first.
      __             __
/`'- \'._____\ (_____.'/ -'`\
  '._. :  _|_| |_|_  : ._.'
     ````` /T"Y"T\ `````
https://linustechtips.com/topic/1030182-prenatal-control-help/#findComment-12269190
