Audio doesn't work, Help!!
Go to solution Solved by mariushm,
Right click on speaker icon, select playback devices, make sure your programs output to the right sound card.
Go in Device Manager and check that all drivers are installed and working correctly.
Get back to us after you check these.
my audio doesn't work, if i tried to troubleshoot with windows troubleshooter, windows troubleshooter can't fix it automaticaly
troubleshooter tell me i have 2 problem ( Audio service not responding and audio format not set to default) so i tried to restart my pc, windows audio services, reopening the driver still doesn't work
i have 2 driver and both of driver was working (nahimic 2+ and realtek hd audio manager)
i tired to test audio with realtek and doesn't work test with sound option there is a error pop up Failed to test tone.
https://linustechtips.com/topic/1029613-audio-doesnt-work-help/
https://linustechtips.com/topic/1029613-audio-doesnt-work-help/#findComment-12263815
i
tried to reinstall realtek and uniinstall nahimic now mic has been detected and working properly but sound still doesn't work
https://linustechtips.com/topic/1029613-audio-doesnt-work-help/#findComment-12263898
somehow now audio working
https://linustechtips.com/topic/1029613-audio-doesnt-work-help/#findComment-12263902
