bottleneck I cant figure out the problem.
Solved by BigDamn,
This is CPU bottlenecking. Your GPU isn't able to hit 100% usage (where it needs to be) because your CPU is too slow to allow it to. As for the ram, are you running 4x2gb (4 sticks 2gb a piece) or 2x4gb (2 sticks 4gb a piece)? Just curious as its confusing how you wrote it. Generally speaking, you want to have matching ram for stability and speed reasons. You force all of your sticks to run at the lowest frequency of the bunch, so even your 1600mhz stick(s) is running at 1333mhz.
Would I upgrade to the 4460? Probably not. If you plan on buying new ram anyways you should shoot for something on the DDR4 platform. Take a look at some Ryzen CPU's.
