Power Saving
RTX2060 is probably going to be better for you power savings wise.
I guess when we look at power savings we look for Watts to FPS.
a 2060 is going to give you about 20-30% more FPS for around the same amount of power as a 1060.
But Nvidia cards will throttle down to like 800Mhz when they aren't in games so you get power savings while not gaming.
You can also find the sweet spot with MSI Afterburner instead of overclocking the card you can unlock the voltage and try undervolting the card.
This will give you decent power savings if you can get a stable clock also the fans will spin less.
Undervolting is popular on Laptops for Power Savings and thermals.
buying an RTX 2080 Ti is in the 200Watt area and even if you clock it down you are pretty much going to get 2060 power usage at a lower clock there is no point buying the hardware.
Remember power savings is based on Architecture usually, hence the 10XX series of Pascal was a lot better than the 9XX series power savings wise.
The GTX 1070 is a nice boost of performance and isnt that power hungry for 1080p gaming it would be fine. obviously the RTX series will be better but it will be priced more.
Just stay away from AMD if Power Savings are your key area, AMD are known to draw the most power to keep up with Nvidia.
