Doing a build with taxes and i am still up in the air for what CPU or CPU's I want. Looks like $550 is going to be my limit for just the CPU. I have a budget set of $1800 for the computer and another $400 for Monitor/Mouse/Keyboard.
I will be using this for basic tasks, running a few VM's at one time, Plex Server with some on the fly transcoding which I am going to try to use a GPU to get most of that done to take the load off the CPU looking into a RTX 2060 or a Vega 56.
I will be doing video transcoding with handbrake 3-10 videos a day. I will be running ICS for my internet connection so this PC will be always on. I already have a 360mm rad that I will be running in custom loop for cooling.
I will be doing occasional gaming nothing crazy but would be nice to unwind with some first person shooters and racing games once in a while. I will be running a 1440p monitor.
Been looking at i9 9900k, ryzen threadripper 2920x, Also been looking on ebay at used dual Xeon's would like E5-26xx v3 so i could use DDR4 memory but if I can get a better clocked E5-26xx v2 I would go that route as well. I care about single thread performance, multi thread, and power consumption as it will be on 24/7 365.
Thanks for any thoughts any if you have experience with any of these CPU's please let me know your thoughts and any benchmarks you have done. I love to see real world cinebench scores for Overclocked chips to see what they are capable of.
EDIT:
I most likely will be getting the CPU new from Microcenter so keep this in mind on pricing. Or ebay if i go with Dual Xeon's
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1027998-help-choosing-a-cpu/
CPU: AMD - Threadripper 1950X 3.4 GHz 16-Core Processor  ($589.99 @ Newegg)
CPU Cooler: Noctua - NH-U12S TR4-SP3 54.97 CFM CPU Cooler  ($69.90 @ Amazon)
Motherboard: ASRock - X399 Taichi ATX TR4 Motherboard  ($324.98 @ Newegg)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($89.99 @ Newegg Business)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive  ($57.99 @ Adorama)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: Zotac - GeForce RTX 2060 6 GB GAMING Video Card  ($348.99 @ SuperBiiz)
Case: Fractal Design - Arc Midi ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 750 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($104.99 @ Newegg)
Total: $1786.70
Generated by PCPartPicker 2019-01-31 03:08 EST-0500
something along the lines of this i presume.
casechoice is if you ever wanted a storage server.........
https://linustechtips.com/topic/1027998-help-choosing-a-cpu/#findComment-12250311
