What's up. I've got a GameCube that continually gets stuck on the base screen on Path is Radiance. It's triggered by scrolling through the units list I think and doesn't seem to stop on any particular unit. It makes this freaky looking error screen that I'll attach where the normal black screen is displayed behind the unit sprite on the base screen. The game has also gotten stuck during combat, leveling up, and transforming.
I know very few people are experts on Path of Radiance but given that the crashes don't seem tied to a specific character would I be correct in assuming that the problem is either in the GameCube itself or the memory card?
I've cleaned the lens on the console and reset the lens rocker position but it always ends up in the same position after the crash, just outside of the center position.
Sorry for the rant but it's gotten infuriating.
Thx
3600X @ stocke | 5600XT TUF OC @ 1850 | 2x16 + 2x8 RAM 3200 HD | 1tb Samsung 970 EVO Plus | Lian Li 205M | TT Toughpower Grand RGB 850 | throwaway b450 asus mobo | BQ cooler
https://linustechtips.com/topic/1027710-gamecube-help/
1 minute ago, KarathKasun said:
Check the cooling fan and replace if its not working.  Also try cleaning the optical drive lens.
I'll try the fan, I didn't think of that. Thanks
https://linustechtips.com/topic/1027710-gamecube-help/#findComment-12247800
38 minutes ago, LordOTaco said:
Careful when cleaning those optical lens Adam Koralik has a good teardown and cleaning video on it.  Listen to it.  Learn it.  Love it.
Thanks speedowagun
https://linustechtips.com/topic/1027710-gamecube-help/#findComment-12247956
To update, I'm fairly sure the problem is a bad fan and thermal issues make sense. I bought it 3rd+hand so it's probably time to replace it anyway.
https://linustechtips.com/topic/1027710-gamecube-help/#findComment-12248091
31 minutes ago, Majinhoju said:
any marks on the disc itself?
The disc is nearly flawless, I was lucky to get it in such good condition.
https://linustechtips.com/topic/1027710-gamecube-help/#findComment-12249045
