Be Quiet! Dark Rock Pro 4 fan issue.
Solved by Special Agent 星雨,
Edit - Cooler Master? I'm high as a kite, I meant Be Quiet.
Thought I'd just post an update - Cooler Master Be Quiet did confirm via e-mail that you do indeed need a decoupler (this rubber thing that sits between the fan and the heatsink, the front 120mm has one by default, but there are no extras included in the box) to allow a silent wings fan to be able to work in the rear orientation, odd, considering they include metal brackets but not this decoupler?
With that said, a free one is being sent out so I cannot really complain, but if others encounter the same issue just have a chat with Be Quiet customer support!
